The negative side of the battery should have a heavy battery cable going from a quality battery terminal to ground (preferably on a starter mount bolt. This battery cable should be at least 2 gauge wire. It supplies the complete ground system for the tractor. No "extra" wires should be between those connections. (I think this is the main issue) From the positive terminal of the battery there should be one battery terminal only hooked to the same size 2 gauge cable, no other connections. The other end of this cable goes to the starter relay (solenoid it is often called). That relay should have 4 terminals 2 big and 2 small. The small terminals are labeled S and I. (If only 3 all is well) The S terminal goes to the push button for starting, 12 ga is good. The big terminal close to the S terminal goes to the above mentioned + battery cable. That big terminal also has a #10 wire hooked to it going to the amp meter (only there). The Other big terminal on the relay goes to a metal connector attached to the starter input terminal. The "I" terminal on the relay goes to the ignition coil + side. It is to bypass the ignition resistor giving the coil full voltage. If this is not there we will worry about it later, it is not needed if the coil is a full 12v coil with no resistor required. Get this wiring correct and lets go from there. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
