Posted by Yooper Farmall on February 19, 2015 at 08:51:07 from (141.210.112.191):
I recently bid on a rear wheel weight for $25, went to go pick it up and the parts dealer had 3 more. I picked up 4 in total for $25 each. I walked around the 2 Farmall H's he was parting out and saw a pto delete plate which I hadn't seen before, and also noticed one had a cast iron shift knob. It is stamped with 9637D but I can't make out an old IHC logo. I understand at some point during the war when rubber was in short supply they made cast iron instead. From a Google search, I have seen 1944's, 1945's, and 1946's with cast iron. I imagine not all came with them. It appears the knob is threaded onto the shift lever, I can't un-thread it by hand, I'll try some WD-40 and a wrench. I'm wondering if the rubber replacements are threaded or pressed on. If I did get the cast knob off, would I even be able to put it on my current shift lever?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
