That does not look like an adjustable priority valve to me, an if it were, I doubt adjusting it would make any difference. They don't spontaneously change adjustment.
Odds are your pump is going bad. Turning the wheel actually takes LESS flow than holding the wheel steady, because the steering motor is blocking the flow in order to create the pressure. That diverts more flow through the lift circuit, making your lift seem to work better.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
