Re: MD injectors
Posted by Russ600 on February 27, 2015 at 08:07:47 from (162.212.68.75):
In Reply to: MD injectors posted by 400dtractorman on February 26, 2015 at 19:53:56:
Hi
An old machanic introduced me to this method. Disconnect the diesel lines and back the nuts that hold the injectors in about 4 turns, Set the engine to diesel mode and then roll the engine over with the starter. I have used this method on a WD 9, and the precup even broke lose.
Cheers
Russ
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
