Posted by rvirgil_KS on March 01, 2015 at 13:56:34 from (8.36.243.55):
In Reply to: IH 606 AMP Light posted by IAtractorKid on February 28, 2015 at 19:16:43:
12 volts is applied to one side of the light, other side of light grounds through armature post and generator. When the generator goes to charge, there is 12 volts output from the armature. 12 volts is on both sides of light so it goes out.
Since the light glows your light blue wire should be ok.
If this is a type a generator system, with engine running ground the F terminal on generator. If light goes out the regulator side of the regulator and/or wiring is bad.
If light still glows, jumper from armature to BAT output on regulator. If light goes out the cutout side of regulator is bad.
If light continues to glow, you have bypassed the regulator so suspect generator or wiring problem.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
