Thanks Jim!!!!
Posted by 300guy on March 12, 2015 at 19:44:50 from (76.85.161.57):
Last fall I posted a question about setting the end play on the bearings on a C-24-P mower's flywheel shaft. It had shims on the cover plate. Anyway Tuesday when I was up to the farm to replace then, you said you installed the bearings and then tapped on the end of the shaft to set the bearings. It worked like a champ!! When I first put the cover on and tightened it up, the shaft would not turn. So I tapped on the end and after 3 or 4 light taps the shaft turned nicely!! So I sealed it up and put it together. Putting the flywheel on was a real pain to drive it back onto the shaft!!!!
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
