Re: valve tappets ( cam followers )
Posted by Janicholson on March 13, 2015 at 09:00:49 from (199.17.6.26):
In Reply to: Re: valve tappets ( cam followers ) posted by Andrew Z on March 13, 2015 at 08:44:44:
And put them back in the exact same hole (even if they get resurfaced, the best practices include pushrods in this tactic. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
