If the voltage on the wire between the coil and distributor remains constant(doesn't drop to zero when the points close), then the points are not making good contact. When the points close the voltage between the coil and distributor should drop to zero. It doesn't take much oxidation to interrupt the current flow and cause problems. I think cleaning the points will fix the problem.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
