Pretty common problem for any tractor that sits for a few days. The float needle sticks, bowl is full of fuel yet when shut off, so it runs until that fuel in bowl is used up. Old distillate H and M's had a pet cock on bottom of carb so if it has you just open that to see if gasoline comes out.
If no petcock, they all have a 1/8th inch pipe plug to remove to check for gasoline flow into carburetor. A good rap on carb with a plastic handle of screwdriver usually will get you going. If stuck bad you will have to disassemble carb and clean needle good. Viton tipped needle are usually the ones that stick.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
