175 puller??
sonny
02-09-2001 04:59:13
i want to know what some of you think of me pulling my ac 175 at a tractor pull next year. it has a 248ci perkins diesel with 16.9x28 rear tires and i run a straight pipe off of it. it weighs roughly 8000lbs. do you think i should pull or just completely forget about it.
Dean
02-09-2001 09:29:02
 Re: 175 puller?? in reply to sonny, 02-09-2001 04:59:13
Do it! If you are going to pull, do it right.
Find out what the rules are for modifying the fuel injection pump and then find an ADS
injection pump shop that works with tractor pullers. They will do magic on your injection
pump and then with a stock bore and stroke engine you should be able to do real well at the tractor pulls. Always glad to see an
orange tractor out there in a sea of green!
Good luck!
