Rock Kicker?
AC Impaired
03-16-2004 18:18:21
There is a WD-45 in the photo ads that has "optional rock kicker hand clutch".Could someone explain what a rock kicker is.Thanks
JMS/MN
03-17-2004 08:23:54
 Re: Rock Kicker? in reply to AC Impaired, 03-16-2004 18:18:21
It does what John says. Look for a U-shaped bracket mounted above the C frame, near the lower end of the hand clutch lever. There is a linkage that goes down to the heavy spring above the Snap-Coupler bell. The clutch lever gets pushed forward when some really hard object is struck.
John (C-IL)
03-16-2004 19:03:56
WHen you are plowing and catch an immovable object with the plow the kicker will kick the hand clutch out of gear.
