2390?
Tpost
02-08-2007 09:11:05
I am looking at a 2390. Were these good tractors and did they have any common problems to watch out for.
Also what is the going rate for a 1983 mod with good duals, Loader, and everything is good working order.
Any advice is greatly appreciated.
Tpost
02-09-2007 04:09:45
 Re: 2390? in reply to Tpost, 02-08-2007 09:11:05
Thanks everyone, I am going to check this more closely and see if I can deal. I hope I can get it. Ill post if I do or not and mabe send some pic's.
big orange
02-08-2007 15:21:48
Had 3 2390's at one time. Never had any powershift trouble, put a torque limiter in one at 2800 hrs. An 83 model probably already has the heavy torque limiter. Great engines and hydralics, good cab. Let tractor warm up in cold weather, cold oil is hard on the powershift. Check the sediment bowl on the tranfer pump, if it's dirty, the tractor probably hasn't had good care. Check controls for free movement.
case trader
02-08-2007 12:02:58
not to start a argument but, you want an will love the power shift w/a loader they are tough if maintained properly ,they only have a 1000 pto, the 504 engine is practily indestructable an not to bad on fuel. not to bad mouth the 8 spd. never seen one in a 2390 have had a couple in the 20 an 2290 a little clumsy, not nearly as bad as the 70 series. but the high an low shift are prone to wear in the 90 series an are no longer avaible from case.
Raleigh
02-08-2007 10:42:23
If its a power shift atch out!! If you can find it with an 8 speed manuel you better grab it ASAP!! I here the 8 speeds are virtually indestructable!!!!
I have looked for an 8 speed case and could never find one! I think that 502 turbo charged engine is SWEET!!!
kirk in ks,
03-16-2007 06:30:02
 Re: 2390? in reply to Raleigh, 02-08-2007 10:42:23
It,s a 504ci turbo, like my 2670 has in it,
ohh m,ann, it,s really sweet, and ready to pull apart anything green that get,s in it,s way,
JoeBob/IN
02-09-2007 14:04:12
Its a 504 turbo and the 2390's didn't come with the 8 speed.
