15-27 and 18-32 serial number locations
SDLars
06-07-2007 19:54:12
Do the 15-27's and 18-32's have a serial number anywhere other than on the plate attached to the fender?
Nebraska Kirk
06-08-2007 21:08:30
 Re: 15-27 and 18-32 serial number locations in reply to SDLars, 06-07-2007 19:54:12
The only Case 15-27 that I have seen has an oval serial number plate attached to the right side frame just under the radiator.
third party image
Brian in Ohio
06-08-2007 07:34:55
I don't know if those tractors have it in the same place as a 12-20, but it's worth a look.
On the driver's left hand side, where the gasoline starting tank is located, go straight down to the frame, and turn back toward the rear wheels. The serial number should be stamped on the frame.
SDLars
06-08-2007 19:14:51
 Re: 15-27 and 18-32 serial number locations in reply to Brian in Ohio, 06-08-2007 07:34:55
Thanks! I'll check it tomorrow.
