400 diesel water pump front axel
D Brown
07-03-2002 21:45:42
I would like to find out if a water pump off a 730 will fit my 400? And my 400 does not have power steering and the 730 that i found for parts does have it will the front axel and steering parts off the 730 fit my 400 they are both deidel?
Thank you D Brown
brian
07-05-2002 19:09:00
 Re: 400 diesel water pump front axel in reply to D Brown, 07-03-2002 21:45:42
Yes they will work. I put a water pump off of a 401D on my 831D and just changed the pullies. As for the power steering they will work but I think some of them had a different bleeding system but will still work.
brian in ky
buckmaster700
07-04-2002 19:17:31
yes if you have the same pullies on the water pumps the should change and you can bolt the whole front end to your block for the power steer
