401 case eagle hitch wont lift without using remote handle
D Brown
08-10-2002 21:22:59
I have a 401 case the eagle hitch will only lift part way unless i hold the hitch handle and also pull back on the remote handle at the same time. does any one know how to fix this problem. also i am looking for the wiring diagram for the same tractor thank you D Brown
Ol Chief
08-11-2002 17:19:41
 Re: 401 case eagle hitch wont lift without using remote handle in reply to D Brown, 08-10-2002 21:22:59
Possibly a bad o-ring on spool valve.
RoyG
08-11-2002 11:35:05
soundslike you have a bad thermo releif valve in the presure side of the control valve- or someone has hooked the hoses up to the wrong outlets. Either of these could cause that.
Michael Draper
08-11-2002 05:53:30
Actually, it sounds(from what little you've said) like you have some sort of valving problem in the pressure system.
Michael Draper
08-11-2002 05:50:21
Sure, Pull it off the tractor, and sell it to me.
