411 case
keyman
02-13-2003 22:16:49
Went and looked at that 400 case today.
It is a series 400 model 411 sn#8066355.
8 speed eagle hitch, with top bracket for 3 point.
One small dent in hood, other than that it is in good shape. Tires about 75%.
It must be in the 50 HP range.
From the archives, sounds like it is a pretty good tractor.
Are they hard to get parts for, Dosen't show up much in sn listings and parts books that i have been looking at.
Is it worth more than a straight 400?
Thanks in advance for any information on this series of case.
Slowpoke
02-14-2003 02:13:48
 Re: 411 case in reply to keyman, 02-13-2003 22:16:49
It should be a gasoline tricycle, 47hp dbr, 55hp belt @ 1500 rpm. 251cu in. Weight 5563. New SRP $3535.
400, 401, 402, 403, 405 are diesels. 410, 411, 412, 413 are gas. Serial # is Year Model 1956, made in 1955. Begining '55 is 8060001. Value-?
Terrance
02-17-2003 13:26:25
 Re: Re: 411 case in reply to Slowpoke, 02-14-2003 02:13:48
a 411 has an adjustable wide front end and is a general purpose tractor with adjustable rear tires/hubs that slide on the axle shafts.
Terrance
