1954 vai . rear pto
joe
05-25-2003 14:38:29
i am thinking about purchaing a 54 vai but want to know if I can put a rear pto on it and how much it might cost.
Mike from Canada
05-25-2003 20:08:42
 Re: 1954 vai . rear pto in reply to joe, 05-25-2003 14:38:29
should be no problem. just make sure that before you attach the new cover to the transmission, you slip a splined coupling or a "sleeve connector" as Case calls it onto the transmission input (main) shaft to connect it to the PTO drive gear assembly.
providing the PTO housing you install is complete, youre ready to go!
good luck
mike
