1958 Case 310b Lack of power?
Andre
12-21-2003 10:24:36
Started looking into the engine and why it was lacking power.
Seems to be firing on 2 cylinders?
All have spark, need to check the compression and valve lash still, but the 2 center cylinders (that do not fire) have compression.
The head has been recently rebuilt, no valves seem to be sticking? Any ideas?????
Gene Dotson
12-21-2003 17:15:22
 Re: 1958 Case 310b Lack of power? in reply to Andre, 12-21-2003 10:24:36
I did an AC cA once that acted exactly the same way. Replaced the plugs and still the same. Checked the firing order and darn if I hadn't set it up Going counterclockwise instead of clockwise. Had a red face on that one. Firing order is 1-3-4-2 going clockwise as you look down at the cap... Gene
Don L.
12-22-2003 16:49:51
 Re: Re: 1958 Case 310b Lack of power? in reply to Gene Dotson, 12-21-2003 17:15:22
I bought a tractor like that, looked it over and over, checked the valves and such . Yep..... those wires were on in the wrong rotation. Happy Day, DL
