1968 W10 Brake Problems
David Yaworski
08-27-2004 21:26:07
I am currently working on this unit and have found all the brakes were seized at the pivot pins and the wheel cylinders I renewed. The master cylinder was renewed by the person that owns it but the problem is now that the pedal fades after you let it sit for about 5 mins. The Hydra-Vac system seems to work and works up to 25lbs or better of vacum. There is no leaks in the system but the pedal fades which causes a no brake situation. Any ideas?
