1960 model 530 Case
JGarner
04-15-2005 08:56:58
I am loking at a 530 Gas dual range tractor on e-bay. The seller says the tractor only works in low range. If this tractor's transmission set up is like our 830 was then the hi/lo range was somewhat like a two speed rear end on a truck. What could potentially be wrong that it won't go into high range? Would like to have some of your ideas, I have my own, before I bid and fool around and win the bid!!
Dennis/Ohio
04-15-2005 17:44:13
 Re: 1960 model 530 Case in reply to JGarner, 04-15-2005 08:56:58
Most likely the model tag is missing and its a 540-H with solid steel front axle & shuttle shifter. Or its a 541 general Purpose with a Dual Range. Either way the Dual Range is a transmission in front of the 4-speed and inside the torque tube. High speed is actually direct drive through the Dual-Range. Problem could be minor shift fork, shift rail, cover/detent.
Best wishes, Dennis..... ..
JGarner
04-19-2005 11:42:32
 Re: 1960 model 530 Case in reply to Dennis/Ohio, 04-15-2005 17:44:13
Thanks for info, I was going to bid on this unit on e-bay when it was $801.00 I had it in my watching file until it got a $400 instant increase, then went out of my price range. Good info anyway, might use again on another.
