early VAC with cracked block
1031D
04-06-2006 19:25:27
I have a 1943 VAC with block casting #VT-149, and it is cracked between every sleeve from top to bottom. Is this common? Are these blocks hard to find? Has anybody had any experience welding one up?
Jerry W
04-07-2006 20:22:54
 Re: early VAC with cracked block in reply to 1031D, 04-06-2006 19:25:27
If they are cracked in the webbing you will probably also find a frost crack behind the carburator. They generally do not crack the webs unless the block has somehow been stressed - usually by frost.
Jerry
1031D
04-08-2006 04:31:05
 Re: early VAC with cracked block in reply to Jerry W, 04-07-2006 20:22:54
that's the funny thing, the block behind the carb is fine.
John Saeli
04-07-2006 04:33:43
If they are in the webbing as you describe, they are not uncommon. The Head Gasket will seal them over. We "V" them out with a Die Grinder & fill them with J-B Weld. They won't bother.
1031D
04-07-2006 18:22:52
 Re: early VAC with cracked block in reply to John Saeli, 04-07-2006 04:33:43
Here's the problem John, the block is also cracked at the bottom of the sleeves and it was pissing oil into the water jacket from the center main oil galley.
