Power steering for a M
Tom W
04-14-2001 05:05:21
I have an old M with a front end loader that is a little tough to steer with a bucket full of snow. I am thinking of adding power steering. Can anyone tell me which is the best kind. How much trouble is it to put on and how much I would expect to pay. Also where could I find one? Thanks.
Knut
04-14-2001 15:02:46
 Re: Power steering for a M in reply to Tom W, 04-14-2001 05:05:21
Larson-Swanson Company at Fort Dodge Iowa used to have a square plate in their catalog that looked like a wedge from the side and had 4 corner holes in it. You placed this between the Steering bolster and the front axle pedestal and it straighten or made the pedestal more perpenticular to the ground to make the tractor steer a little easier. Not as easy as power steering but much easier. Also be sure the lower bolster bearing is clean and greased.
Farmer Bob
04-14-2001 09:04:54
third party image
Tom, I added a Char-lynn unit to my '48 M last year. Got it off the YTMAG auction block and only had to replace a couple of gaskets. With this type of mounting there were no hood modifications required. The motor section mounts just ahead of the gauge bracket with the shortened front steering shaft. Works like a dream...one finger steering!
Tom
12-17-2003 09:22:26
 Re: Re: Power steering for a M in reply to Farmer Bob, 04-14-2001 09:04:54
I just bought a "M' and would like to add power steering. I picked up a used power steering motor assembly. The guy told me I could hook it up to my existing hydraulics that run my loader. There are four ports on the motor, I can identify 2 of the four. One is G1 , and the other is G2. What are the other two ports for and how do you plumb the motor up? Your assistance is appreciated in advance.
The Red
04-14-2001 09:14:17
Bob thanks for the picture. I swiped that and stuck it in my 51H directory. :)
Bob M
04-14-2001 06:28:28
Tom - I've put Charlynn PS kits on a couple Super M's. Installation was straightforward, and the steering is powerful and trouble-free.
Click below to for installation instructions and photos of the hydraulic hookup.
JohnIH
04-14-2001 05:33:04
Tom W,
The most common aftermarket power steering used is probably Char-Lynn. I have one on my 400 that someone else put on. Good luck in choosing.
JohnIH
The Red
04-14-2001 05:10:48
Tom if you have some time, type in power steering in the search box and hit the go button. You will find numerous helpful threads on this topic.
Tom W.
04-14-2001 05:24:09
 Re: Re: Power steering for a M in reply to The Red, 04-14-2001 05:10:48
Hi Red. I can always count on you for a response. I already did that and most of them were last years. I just thought someone has had more recent experience. Did you ever add power to any of yours?
The Red
04-14-2001 05:40:13
 Re: Re: Re: Power steering for a M in reply to Tom W., 04-14-2001 05:24:09
Afraid not Tom. Sorry I couldn't be of help. I had an IH loader on a rough M at one time. Even Magilla Gorilla had trouble turning the steering wheel. :(
gene b
04-14-2001 20:51:33
 Re: Re: Re: Re: Power steering for a M in reply to The Red, 04-14-2001 05:40:13
you guys are a bunch of softies we had a SUPER-SIX loader on an M didnt steer that bad loaded lots of cattle stuff and the big 8ft snow blade to clean off the drive and 1/4 mi lane to the road and so forth without power steering got along great loader had trip bucket not even live hy easy to do just have to learn how to run steer on the move and move levers at the same time
