Farmall MD overcenter hand clutch
Rodney Axford
01-24-2002 12:31:06
HELP The clutch is not shown in any IH or Farmall manuals I can find. It is a MW hand clutch. It never did work from the time I bought the tractor. It was tightened to the point it wouldn't disengage to keep it from slipping because it was running in gear lube due to leaking seals. I replaced all the seals, washed and cooked the fiber disks to get rid of the oil. I reassembled as it was when I pulled it out. It still doesn't work. It doesn't have any over center snap. when I took it apart I saw that the metal disks between the fibers are dished "(". Is it possible that these are backwards? The dish was on the shaft with the (--- towards the transmission. I'm pulling it out again. I would really appreciate any info anyone can give me on this clutch. correct assembly, web links, manuals, anything. Thanks, Rodney
Farmall Paul
01-24-2002 14:17:28
 Re: Farmall MD overcenter hand clutch in reply to Rodney Axford, 01-24-2002 12:31:06
Rodney- I e-mailed you a scan of the parts breakdown. Hope you can read it.
Jeff
01-24-2002 17:12:19
 Re: Re: Farmall MD overcenter hand clutch in reply to Farmall Paul, 01-24-2002 14:17:28
Hey Paul, is there any chance you could send me that scanned document too. I have a MW hand clutch that does not work as well and I have not been able to find any literature that would be able to help me take it apart and fix it. thanks a lot!
jeff
Jordan Flagstad
05-15-2002 20:15:35
 Re: Re: Re: Farmall MD overcenter hand clutch in reply to Jeff, 01-24-2002 17:12:19
Hey Paul,
Could I get the scan too??
Thanks,
Jordan Flagstad
Minneapolis, MN
jordanflagstad@aol.com
adam
01-25-2002 16:22:34
Hey paul sorry but if it isnt to much trouble could you send me that to please
Farmall Paul
01-25-2002 07:37:36
Jeff- I sent you one. Thanks to whoever sent it to me - last year!?!? Hope it helps. Paul+
Seeing Red
01-25-2002 03:10:19
I have an installation manuel from one of these. They cover its installaton and operating procedure.
gene von gunten
06-12-2004 11:26:13
 Re: Re: Re: Re: Farmall MD overcenter hand clutch in reply to Seeing Red, 01-25-2002 03:10:19
Help! I have a Farmall Super H with the MW clutch. Does someone have some info on it that they could email to : vongunten@msn.com
Many thanks!
