Tractor Cab for 706
Carp
02-20-2007 10:43:07
Well, I bought the cab off of a 1066 to put on my 706. It is the cab that has flat sides and hangs way over the back, not the one with the angles in the door.
Anyway, I have a couple of questions. There is a multipin connector that connects the electrical system of the cab to the tractor. Does anyone have or know where to get a wiring diagram for the cab? Does anyone have any drawings or instructions on just exactly what fits where to mount the cab? I am sure it can be figured out easily enough, but pictures always help. Last, it has an AC unit, but no compressor. Will any AC compressor work with this system or would I need to get a specific one.
Thanks for any help.
Allan In NE
02-20-2007 12:11:48
 Re: Tractor Cab for 706 in reply to Carp, 02-20-2007 10:43:07
I'm right in the middle of two of the old darlin's. Just let me know what you need. My email is open.
On the electrical connector:
1. White w/red tracer is the left turn signal
2. White w/green tracer is the right turn signal
3. Yellow is the compressor feed wire
4. Green feeds the dome light (always hot off the light switch).
5. Two big Black wires are the power feeds for the blower motors. One for the fan and the other for the condenser fans.
6. That "extra" small loom runs the field lights, one on each side of the cab.
Did you remember to get the relay center inboard of the right battery? Gotta have that.
Did you get the cab mounting irons? These are what bolt to the tractor.
Yes, just about any compressor will work.
Allan
