Re: Timing a IH 140 - best method
El Toro
02-23-2007 09:14:03
If you can locate the timing marks on the flywheel
I would chalk that timing line and then use a timing light to set the timing. It will take a helper so you can do this. I use an inductive
timing light from Sears. Hal
CNKS
02-23-2007 17:27:56
 Re: Timing a IH 140 - best method in reply to El Toro, 02-23-2007 09:14:03
If it's like the Super A, there is no timing mark for a light. The one on the flywheel is for static timing. I think on the H/M or at least on the SH/SM there is an advance mark on the crankshaft pulley. One can be added to the A-140 provided the number of degrees at a certain rpm are known, but I don't think there is any advantage to that.
