Could a Farmall H be Postive Ground?
reddheadd
03-07-2007 18:55:58
I am helping a friend get his tractor going and when I went to remove the battery to charge it, I noticed that he had it connected positive to ground and negative to the starter switch. Does that sound correct? The tractor is a 1948, 6 volt system. Thanks.
sammy the RED
03-07-2007 22:25:12
 Re: Could a Farmall H be Postive Ground? in reply to reddheadd, 03-07-2007 18:55:58
That would be the correct way.
JayWalt
03-07-2007 19:42:44
most tractors and auto of that era were 6v pos ground system. I believe in the mid 50s is when they made the switch to 12v neg ground systems.
teddy52food
03-08-2007 06:14:36
 Re: Could a Farmall H be Postive Ground? in reply to JayWalt, 03-07-2007 19:42:44
1949 50 51 52 &53 Chevve's were negetive ground. Ford at that time were positive. I am not sure about chrysler. Chevvy came with 12 volt negetive in 55, Ford in 56.
Jim Becker
03-07-2007 18:59:23
Yes, that is correct.
Mnredfarmer
03-07-2007 18:59:02
That would be correct. Positive ground
