Old Payloader
STUDIEDIESEL63
03-08-2007 08:29:00
Have an old payloader,lookes like a 560 diesel engine ? Rear steering only.Anyone help me with age ,model ,repair manual ?? runs good but tranny seems to slip alot. Any help greatly appreciated !!
Wardner
03-08-2007 11:33:39
 Re: Old Payloader in reply to STUDIEDIESEL63, 03-08-2007 08:29:00
I assume that you have a factory installed 53 series Detroit Diesel powered Studebaker. Would you care to comment on your truck? I still have my '47 IH KB-5 w/4-53. I installed it several years before the fuel crisises in the '70s.
STUDIEDIESEL63
03-08-2007 17:52:12
 Re: Old Payloader in reply to Wardner, 03-08-2007 11:33:39
Yes it is. It`s a stub-nose E-45 with a 350 bushel grain box on it,serial no 906 [6th one built] 4-53 with a Clark 5-speed,2-speed rear. It`ll run 70 mph real easy. Only problem ,it will make you deaf!! 68,000 original miles.Sounds like you got a cool truck too !
Wardner
03-08-2007 18:14:03
 Re: Old Payloader in reply to STUDIEDIESEL63, 03-08-2007 17:52:12
I have the Clark 265 VO tranny as well. I love that close ratio four/five downshift.
The engine/tranny came out of a Chevy school bus. I changed the rear end to a electric shifted 2 speed with a lower numeric ratio for more speed. Don't think I ever got it to 70 mph though.
Ya, it is some noisy. I have been thinking about antique plates this year. It would make a good tractor hauler.
STUDIEDIESEL63
03-08-2007 19:02:19
 Re: Old Payloader in reply to Wardner, 03-08-2007 18:14:03
Yah it would make a good tractor hauler,do you have antique tractors and go to shows ? Have a Studie semi tractor as well,its a gasser though. Run real good but pretty rusty.
hectorgemme
03-08-2007 10:11:01
Did you check the transmission oil level
hector gemme
03-09-2007 02:26:37
 Re: Old Payloader in reply to hectorgemme, 03-08-2007 10:11:01
there are no adjustement on power shift transmission and did you change the transmission oil filter and some have a straner but I have a hough 70 and she slipping too but it to late she should be rebuilted.
STUDIEDIESEL63
03-08-2007 17:55:09
Oil level is good ,as has no leaks, any adjust ments that can be made?
