International 434 , 1970
Jacques Leblanc
03-11-2007 16:25:27
Previous owner has drilled an 1/8 hole on hydrolic filler plug located on top behind the seat. I do'nt know exactly the need of that hole, may be the system need to evacuate air pression. So, when I am working with tractor, oil is bleeding by this hole if the front of the tractor is little bit upper then the back.
Is there a problem to put a filler plug without hole or an another solution could be replace the hole?
Thanks
Jacques
Fromjb2
03-11-2007 17:17:16
 Re: International 434 , 1970 in reply to Jacques Leblanc , 03-11-2007 16:25:27
Hi Jacques, we had a 434 and it was a solid pipe plug.
I am curious for reason for 1/8 hole, had the previous owner over filled the reservoir OR not using Hytran hydraulic oil and it is foaming?
JimB.
Jacques Leblanc
03-11-2007 19:26:35
 Re: International 434 , 1970 in reply to Fromjb2, 03-11-2007 17:17:16
Hi, Jim,
The hole has only 1\8 but it bleed a lot when I working with the loader, a 1850 International.. I changed hydrolic oil and I filled as the indication that mean up to the bottom of the filler plug. I don't know if ther is a strainer doing the same job of a 1/8 hole?
Jacques
Fromjb2
03-11-2007 19:48:24
 Re: International 434 , 1970 in reply to Jacques Leblanc , 03-11-2007 19:26:35
Hi Jacques, we had an IH 1501 loader on our 434 and later traded for a 384, same tractor with different skins and an IH 1550 loader. The loader return was plumbed into the filler plug with a "T" pipe and the plug was on the top of the "T". If I remember correctly full is an inch or so below the filler hole. It can make a difference if the loader is fully raised especially if it has single acting cylinders on the boom.
JimB.
