international 2400 D179 engine
tom generelli
03-18-2007 18:25:09
Hi
I was just wondering if anybody has experience with an international 2400 with a D179 3cyl international engine. The problem I'm having is it always has white smoke coming out of the tail pipe hot or cold. the engine runs and starts great even in cold weather.i had someone look at it they said it could be an injector pump (very costly)or bad injector.
i would just like second opinion before i have the work done.
thanks tom
FromJB2
03-18-2007 18:36:18
 Re: international 2400 D179 engine in reply to tom generelli, 03-18-2007 18:25:09
Hi Tom, never worked on a 2400 but have worked on the D179 in a 454 and 495.
Since it starts easily that would eliminate the injection pump timing. I would suspect an injector is leaking.
Is it loosing coolant?
These engines are very reliable. My brother's 454 has over 15,000 Hrs on it. Still runs great.
JimB
tom generelli
03-19-2007 20:43:12
 Re: international 2400 D179 engine in reply to FromJB2, 03-18-2007 18:36:18
thanks for the info. i will just have the injectors rebuilt or buy new ones.coolant is still full to.
thanks tom.
