Hydraulic Diverter
ToddL
03-21-2007 16:04:50
I have the thing plumbed so pressure is going to the diverter and to hydraulic pump on steering column. I have the EX (excess flow) and the oil coming out of the pump on the steering column teed together. That flows to a port on the left side of the hyraulic reservoir. There was a male pioneer coupler there and I removed it. Will this port accept oil flowing from the diverter? Right now the power steering does not work!!! Must be a blond moment!!!!! !!!1
Keith-OR
03-21-2007 23:09:11
 Re: Hydraulic Diverter in reply to ToddL, 03-21-2007 16:04:50
Todd, not sure exactly which flow control valve you are using. Why are you using a flow control valve(hydraulic diverter)? If you are using it to run more than one hydraulic system from one pump, you have it plumbed wrong. Primary pressure go directly to the diverter(flow control valve)and CF should be hooked to your steering. EX should go to your other hydraulic system.
Also have no idea which tractor you are working with. really need more info
Keith & Shawn
Bob
03-21-2007 17:18:44
1.) Aren't you using the EF (excess flow) for other hydraulics that you are attempting to return it to the tank?
2.) Doesn't the diverter (divider) have a small port labled "T" (Tank)?
