H starting handle.
richard in nz
03-24-2007 04:23:27
Had last week off work to use up some outstanding holiday and got quite a lot done on my '44 wide front H, all new bearings in the transmission, and a lot of it rubbed down, nearly ready to start slinging some paint about, anyway, where is the starting handle stowed on the tractor? I cannot find any stowage bracket or clips to hold it, or do you guys make your own stowage brackets for it, thanks in advance, Richard, Christchurch, New Zealand.
darndt
03-24-2007 14:03:38
 Re: H starting handle. in reply to richard in nz, 03-24-2007 04:23:27
On our 39 H we used to cary the crank between the frame rail and the engine block it never came out from 1940 till after 1965
Farmer Bob
03-24-2007 08:21:34
third party image
Here is where its stored on our H.
riverbend
03-24-2007 10:23:41
 Re: H starting handle. in reply to Farmer Bob, 03-24-2007 08:21:34
Is your lower radiator hose from a 300 / 350 ? If so, how did you get it to fit / where did you get it ? I'd have to cut the flared end off entirely to get the radiator in the right spot, but then it wouldn't fit over the radiator outlet.
Farmer Bob
03-24-2007 20:26:43
 Re: H starting handle. in reply to riverbend, 03-24-2007 10:23:41
I just went to NAPA and bought a flex radiator hose the right length and size to fit both the lower rad and the water pump outlet pipe. The tractor didn't have the regular flattened steel connector on it when I bought it. As I remember it wasn't hard to bend this flex hose to get it on both ends after installing the radiator.
chuck46
03-24-2007 07:19:46
Hi, From the left side of tractor lay it flat behind the pulley housing, in front of gas tank support. My dads 42 H was a war time tractor with no starter and lights, the crank has been stored there for 65 years now and has never fallen out. Good luck, Chuck
NDS
03-24-2007 07:30:56
 Re: H starting handle. in reply to chuck46, 03-24-2007 07:19:46
I would hang it on back wall of tractor shed if it will not start with starter pull it off I have been around old tractors forever and have seen several broken arms and wrists from tractor kick backs. Crank is good for turning engine over for timing and stting valves but that is all in my opinion.
richard in nz
03-24-2007 16:52:09
 Re: H starting handle. in reply to NDS, 03-24-2007 07:30:56
Sorry mate, this tractor was origanly shipped to England in late 44 and she has no electrics, its hand start only, park at the top of a hill which here on the canterbury plains are as rare as hens teeth, or tow it with a John Deere to start it, which is NOT an option! lol. Just gotta have that handle!
A. Bohemian
03-24-2007 11:03:29
 Quick Question in reply to NDS, 03-24-2007 07:30:56
Have you ever seen an engine with a centrifugal spark advance take off and run backwards?
NDS
03-24-2007 07:38:13
Meant to post under original post.
georgeky
03-24-2007 05:43:14
After reading this again I think so to.
Nebraska Cowman
03-24-2007 04:59:44
No, there never was a place to stow it. Farmers over the years sometimes found handy places where it would not fall off. I remember when I was a kid dad stowed the crank on our Ferguson stuck through the light bracket on the fender.
georgeky
03-24-2007 04:40:25
Richard my 44 H has a bracket on the steering post with a push button starter switch on left side of post.
brainerd dave
03-24-2007 05:01:54
 Re: H starting handle. in reply to georgeky, 03-24-2007 04:40:25
The take I get is that he's talking about the hand crank. I don't have/use one, but we stored it under the seat on the M back in the day.
