Front wheel seals
VAJerry
03-25-2007 11:46:54
Helps to make sure ALL the wheel seals are removed before putting on new ones. Farmall has the most unusual wheel bearing/seal set up. How long did they keep the set up like on the Super A? I can't see an advantage to it.
CNKS
03-25-2007 16:41:31
 Re: Front wheel seals in reply to VAJerry, 03-25-2007 11:46:54
Not sure of the Super A, as the different models are not exactly the same. Basically all you need to replace, unless wear is severe, is the dust seal, sometimes called an oil seal (see below), and the bearings, if worn excessively. The cups the bearings run in are replacable in case of excess wear. I have not replaced the bearing cups, but have replaced the cups the oil seals run in. Those seals just keep dirt, etc out of the bearing, and if the tractor sees little use can probably be ignored, but I don't like to leave out parts.
