SUPER C HEAD ON 113 C.I. ENGINE ?????
THUMPER S
04-02-2007 16:52:52
IF I PUT A SUPER C HEAD ON FARMALL B WILL IT ALSO NEED THE ROCKER ARM ASSEBLY TO WORK ? , AND WILL THIS LET ME USE THE STEPPED HEAD PISTONS FROM TISCO TO GET MORE COMPRESSION, IS THERE ANYTHING ELSE I SHOULD DO ????? ?? THANKS FOR ANYONES HELP...
CSR
04-03-2007 03:33:11
 Re: SUPER C HEAD ON 113 C.I. ENGINE ????? in reply to THUMPER S, 04-02-2007 16:52:52
I just redid a C113 using the TISCO stepped head piston overbore kit. The domes are .375 high. I measured the valve lift prior to disassembly and it was ~.250. The combustion chamber depth to the valves was 1", so I should still have .375 valve to dome clearance. I am painting the motor tonight and will have it fired up in a week or so....
Charles McNelly III
04-02-2007 18:35:30
Thumper, if you mill the factory 113 head .100 and get the pistons from Howard industries instead of Tisco, you will have more them enough power. The H.I. pistons have a taller dome then Tisco. .375 verses .250 I'm running 150 lbs. of cranking compression on my B. I had to drill out the main jet to get the motor to run right. My problem is all traction at the moment. Good Luck,
Charles
CHARLES MC NELLY 111
04-02-2007 21:33:57
 Re: SUPER C HEAD ON 113 C.I. ENGINE ????? in reply to Charles McNelly III, 04-02-2007 18:35:30
WHERE DO I GET THESE PISTON & SLEEVE ASSY. THANKS..... ..
THUMPER S
04-02-2007 21:36:38
 Re: SUPER C HEAD ON 113 C.I. ENGINE ????? in reply to CHARLES MC NELLY 111, 04-02-2007 21:33:57
WHRER DO I GET THESE HOWARD PISTON & SLEEVE SET????? ????? ?
Charles McNelly III
04-03-2007 18:47:54
 Re: SUPER C HEAD ON 113 C.I. ENGINE ????? in reply to THUMPER S, 04-02-2007 21:36:38
www.howardenterprises.com E-mail them and they will let you know the nearest dealer to you. The pistons look really nice. Good Luck,
Charles
