hydraulic problem ?
Don Benson
04-14-2007 18:11:31
Got to run my project 300u today with the brush hog, I noticed the hydralic lines get a little hot, is this normal everything is working fine just concerned, Oh, an update on the clutch/Ta slipping problem, I have adjusted several times but think I am closer, are they that critical concerning the adjustment, or am I loosing my mind.
D Slater
04-14-2007 19:13:39
 Re: hydraulic problem ? in reply to Don Benson, 04-14-2007 18:11:31
Don't know what problem you are having with T/A.
If it slips sometime or all the time in low adjusting won't cure it. With a good T/A unit the T/A clutch could be completly removed from tractor and it would pull just fine in low T/A. T/A clutch engagement and disangagement linkage is all that can be adjusted on outside of tractor.
TomH in PA
04-14-2007 18:59:35
Answer to all of your questions is probably "Yes". Oil gets hot, TA is fussy, and your mind is loose ;^)
Yugrotcart
04-14-2007 18:57:48
It's OK for the hydraulic lines to get warm, but not hot. If you can hold them with your hands without them being too hot, your OK.
Paul
