Front weights and brackets
Trent544
04-21-2007 04:19:19
When did IH change to the weights with the angle iron slot to hold them down? I have seen some brackets with two small holes at the ends to bolt the angle iron to and some brackes without the small holes. I have a 1968 Farmall 544, which bracket would be correct?
Chris from Wa
04-21-2007 13:20:17
 Re: Front weights and brackets in reply to Trent544, 04-21-2007 04:19:19
Trent544: my 544 parts manual specifies front weight bracket #383389R21, 2 cams #536044R1, and weight retaining bar #536042R1. The weight retaining bar is bolted to the weight bracket by two 5/8x11 x 2 3/4 cap screws and nuts.
