problem with 300u voltage regulator
Charlie M
04-30-2007 16:05:24
I have a 12 volt negative ground electrical system on my 300U. It used to work fine but now occassionally the system won't show charge. If I rev up the tractor some and tap the voltage regulator a couple of times it will eventually charge. Anybody know if there is something I can clean, adjust, etc or is it just getting ready to die and I will need a new one. Seems like I have to buy a new one every 3-4 years.
janicholson
04-30-2007 20:18:16
 Re: problem with 300u voltage regulator in reply to Charlie M, 04-30-2007 16:05:24
Remove the cover (may require removing rivets) and clean up all electrical contacts with a needle file, or flexstone point file. Don't adjust anything, and clean out all grit. Re assemble, and give it a try. The cover needs to be on to assure corect output. JimN
Unreserved dick
05-01-2007 00:05:46
 Re: problem with 300u voltage regulator in reply to janicholson, 04-30-2007 20:18:16
Don't forget to check that your regulator is grounded (electrically connected to the tractor frame). That's probably the most important connection, and it's easy to forget about it.
