Torque for bolts on Camshaft Farmall A
history guy
05-01-2007 20:39:26
Do the bolts holding the camshaft into the block in a farmall A need to be torqued? If so, what are the torque specs. I looked all over the manual so I assume they do not need to be torqued down.
history guy
05-01-2007 20:45:02
 Re: Torque for bolts on Camshaft Farmall A in reply to history guy, 05-01-2007 20:39:26
Thank you!!
georgeky
05-01-2007 20:43:58
There is no specific torque setting on these. I just tighten them up fairly even and call it good. You may want to try around 40 lbs. I wouldn't go any more than that to avoid stripping the threads.
