3pt hitch h
bbaro
05-07-2007 03:47:54
hello, i just picked up a used saginaw hitch and i was wondering if any one can give me some info on plumbing it into my lift-all, i do have some manuals on the way. thank you
Hayfarmer
05-07-2007 06:56:06
 Re: 3pt hitch h in reply to bbaro, 05-07-2007 03:47:54
An addition to the below comment, if the hitch has double acting cylinders on it you will need to put a breather in the non used port on the cylinder.
dej(jed)
05-07-2007 04:39:55
Just run a line from one of the pump outlets to the up side of the cylinder. If you have 2 cylinders use a tee and run one line to both of the lift siides of the cylinders.
