Rim Cleaning...would you believe it.
Tom Windsor
05-15-2007 08:12:04
third party image
Almost whole rim went in the tank. Will rotate it in a day or so.
HAS
05-15-2007 11:06:57
 Re: Rim Cleaning...would you believe it. in reply to Tom Windsor, 05-15-2007 08:12:04
Now, that's the easiest way I've seen to use a sledge hammer. LOL
Wardner
05-15-2007 09:07:41
Perhaps you need a larger tank. I have 29 of these open top 1900 gal poly tanks.
third party image
Tom Windsor
05-15-2007 11:56:08
 Re: Rim Cleaning...would you believe it. in reply to Wardner, 05-15-2007 09:07:41
Man....that tank would really suit me. I could dunk some very very large pieces in and just walk away for a while. Cool. Really good. What are these tanks designed for. Where can I get one. I have one of those electrical line trucks with a winch boom on it. Man, I could just put it outside the shop somewhere, winch it up and dunk it and be in business.
TW
Wardner
05-15-2007 12:59:34
 Re: Rim Cleaning...would you believe it. in reply to Tom Windsor, 05-15-2007 11:56:08
Yep, I think an entire tractor would fit. See my other post for more details.
If I had time, it would be fun to fill the tank and submerge a derelict F400 that I have. It should fit without the wheels.
Bob Farrell
05-15-2007 10:13:52
Are they for sale? Where are the tanks located? What's the diameter and height? What's the wall thickness? How much per each? Finally, do you know the chemical composition?
Wardner
05-15-2007 12:52:00
 Re: Rim Cleaning...would you believe it. in reply to Bob Farrell, 05-15-2007 10:13:52
For sale: yes
Diameter as shown: 84"
Height as shown: 94"
Wall thickness: unknown without destructive testing (drilling). There are non-destructive testing methods but I don't have the equipment. I assume 3/8" to 1/2". Strong enough to hold water to full height @ 100 degrees. Temperature rating is probably conserative.
Tank resin is Escorene LL-8400 mfdg by Exxon. It is a medium density linear polyethylene designed for rotational molding applications. I have the data sheet.
Email me for price and more pictures.
Goto calmac.com for more info. Click on IceBanks. I have 28 complete units. The IceBanks were used to make ice at night to supplement daytime air conditioning loads. Each tank can make, store, and melt 190 ton-hours of ice every day.
Bob Farrell
05-15-2007 17:05:35
 Re: Rim Cleaning...would you believe it. in reply to Wardner, 05-15-2007 12:52:00
Maine is too far away for me. Thanks for the reply. Bob Farrell
Bob Farrell
05-15-2007 17:05:06
Wardner
05-15-2007 17:26:25
 Re: Rim Cleaning...would you believe it. in reply to Bob Farrell, 05-15-2007 17:05:06
I am not a Mainiac. MA is Massachusetts. Maine is DownEast from here. Next time you see ME in an address you will know it is Maine.
Bob Farrell
05-15-2007 18:38:38
 Re: Rim Cleaning...would you believe it. in reply to Wardner, 05-15-2007 17:26:25
Sorry-I think I knew better, but why get your shorts in a knot over such a trivial thing. I was only trying to thank you for the reply to my post with all the questions, SIR. Please take a blood pressure pill and sleep it off. In Oklahoma (That's OK) we try not to get so upset over nothing. Have a great evening, and try to relax.
SamC-VT
05-16-2007 17:56:44
 Re: Rim Cleaning...would you believe it. in reply to Bob Farrell, 05-15-2007 18:38:38
Perhaps the Mainiac term seemed odd? As one born and raised in Maine, it is a name we happily apply to ourselves and don't mind in the least being called it by others. Probably sounds odd.
(That tank would make me a real nice gravity-feed watering tank! If the lining is food-grade, sugar producers pay near $1 per gallon.)
Wardner
05-15-2007 20:37:17
Thanks for being so patronizing.
Your perceptions are your problem. If you thought it was a personal attack, you were wrong.
I will say that I cannot understand why a citizen of this country doesn't know the state letter codes. They have been around since 1965.
Every time I use the two letter code, I have to ask myself if the audience will understand. I am not the only one. Many residents still use MASS so as not to confuse others. I choose not to "dumb down" my state's ID.
Bob Farrell
05-16-2007 07:14:50
 Re: Rim Cleaning...would you believe it. in reply to Wardner, 05-15-2007 20:37:17
You are right.
I stand corrected.
I apologize.
I will try to do better in the future.
