IH 140 or International Industrial 140
Tara Delp
05-26-2007 05:18:19
We just recently purchased an international industrial 140, i wanted some history on it. i also, don"t know the year and wanted to know if there was any way to find that out.
Al L. in Wisc.
05-26-2007 14:14:43
 Re: IH 140 or International Industrial 140 in reply to Tara Delp, 05-26-2007 05:18:19
Tara, to find the birth year of your "red iron", at the left side of this page under the "Research & Info" section; click on the "Serial Numbers" link. The link took you to a page w/a list of tractor manufacturers; click on the "International & Farmall" link. On the new page, click on the "I-140 and F-140 link to display the serial number production began w/for that model year. Next, and please follow these directions precisely, walk out your door and hollar in a northerly direction "HUGH". It may take a while as he has revealed he is 65. The meek Canadian is a knowledgeable IH IHC fellow. Shy, but if you coax him a little, he is really full of it...IH knowledge that is...be sure to tell him Al L. in Wisc. sent you.
Tara Delp
05-27-2007 06:03:52
 Re: IH 140 or International Industrial 140 in reply to Al L. in Wisc., 05-26-2007 14:14:43
I checked the serial numbers against what you told me and the one off the tractor doesn't match any of the years. My dad told me it was an international industrial 140 and the serial number is 29782 J, according to him. Is there any reason these numbers wouldn't match?
Hugh MacKay
05-27-2007 14:41:58
 Re: IH 140 or International Industrial 140 in reply to Tara Delp, 05-27-2007 06:03:52
Tara: Don't pay ant attention to the J, that only indicates it has a Rockford clutch. 29782 is your serial number and that makes it a 1965 model.
Hugh MacKay
05-27-2007 02:51:20
Al: Tara allready made the shout north and I responded.
By the way how is the weather in the real north?
SuperA-Tx
05-26-2007 06:40:49
Round axle is a regular 140. Diamond axle is an industrial. Early modles had a pull starter swith and a push button starter. Later ones had a key switch.
If yours is an industrial I would be interested to know if yours has a cast wheel or has a steel flat kind of wheel. Steel ones are solid and the cast ones had three spokes and more open.
Tara Delp
05-27-2007 05:23:49
 Re: IH 140 or International Industrial 140 in reply to SuperA-Tx, 05-26-2007 06:40:49
It has a cast wheel if I go by your description. 3-spokes and rather open.
Bus Driver
05-26-2007 05:41:46
Does yours have a foot throttle?
Tara Delp
05-28-2007 18:56:11
 Re: IH 140 or International Industrial 140 in reply to Bus Driver, 05-26-2007 05:41:46
Hand throttle
Andrew Z
05-26-2007 05:37:54
all kinds of ways these were used from around yards to pull trailers and equipment, they were a multi purpose tractor. As for the year there should be a serial number on the left side of the tractors bell houseing. (the same side as the carb) Also look for cast codes, examople A= 55 B= 56 C=57..... ..
Andrew
Tara Delp
05-28-2007 08:44:06
 Re: IH 140 or International Industrial 140 in reply to Andrew Z , 05-26-2007 05:37:54
What does a cast code tell you? and where would it be located?
