806 gas timing
smdv806
05-26-2007 18:24:23
Does anyone know what the book says how many degrees at what rpm the 301 gas is supposed to be timed?
the tractor vet
05-26-2007 19:38:35
 Re: 806 gas timing in reply to smdv806, 05-26-2007 18:24:23
Yea i know how to time one . best way is to remove the plate on the right side of the bellhousing and find your timing makes on the flywheel and mark the 22 degree mark BTDC with a white paint stick and reinstall the timing pointer and put the two bolts in and tighten them up to hold it in place ,with a good timing lite and engine running at full throttel of 2640 RPM ya set the timing at the 22 degrees BTDC . Now also along with this ya had best be running nothing less the 93 octain gas.
smdv806
05-26-2007 21:34:26
 Re: 806 gas timing in reply to the tractor vet, 05-26-2007 19:38:35
Thanks
