transmission fluid 300U
Scott's Repair
05-28-2007 08:38:40
I'm writing this for my husband, so bear with me. My in-laws have a 300U and my husband does all the mechanical work on it. Long story short, they put some fluid in the transmission or differential that may not be the correct fluid. Now it's running a little funny. We have a manual on it, but Scott has read through it and can't find out anything about the TYPE of fluid that should be in it. He wants to just drain what's in it out and put all new in. Anyone know this? Is there more information that I need to provide? Thanks for your help!
Gary in Mozarks
05-28-2007 17:54:24
 Re: transmission fluid 300U in reply to Scott's Repair, 05-28-2007 08:38:40
Old timers used to use straight 30 weight oil and I believe at one time IH sold an additive that was to be used with 30Wt to make it hydralic fluid. You can get a HiTran equivelant at your local Napa or Tractor supply, Orchelin's etc that will be quite a bit cheaper than buying it from Case/New Holland
Steven@AZ
05-28-2007 11:45:24
Hy-Tran from you local CaseIH or CNH dealer will work great.
If you don't want that, any good hydraulic/transmission combination oil is what you need.
Do NOT use gear lube!
