here's my super H
jonnnny2006
05-29-2007 03:30:35
third party image
This is my 1953 super H ser# 21186J she is a stage 2 and runs like bran new. it has new back tires and a hour meter. hope you like it, I do!
jonnnny2006
05-29-2007 18:27:04
 Re: here's my super H in reply to jonnnny2006, 05-29-2007 03:30:35
the guy i goy it from was selling it as a 54 stage 2. but when he gave me the serial number off the side plate SH 21186. the 54's dinit start till after 22002. so what i got is a some what rare late model Stage II 53. the cast codes all all "Y" castings with the newest cast made on 11-12-Y The casting on the motor is 11-24.Y so shes a 53 for sure. i cannot rember the engine number. i know it is higher than the side number. Some day i'm gonna take her all apart sand her down and have it painted by my cousin. he has painted lots of cars trucks boats tractors and lawn mowers. But What i find neat about this tractor is that except for the new dynatorqe tires on the back (no checking any where on any tire) shes all original and was not used that much. shes spent her life inside a nice dry barn. they used it to rake hay and run a bail elevator, corn auger. so it has not been worked to the bone. it has a new M@W clutch in it and a M@W rocket govener. i have a old govner that can go back on. also it came with the universel wide front made by I.H (it has the .i.h. tage and says "universel" Followed by a serial number). so i might put the orginal narrow back on her and stick the wide front under my M diesel. decisions decisions. Shes runs out so so nice. the rain cap never bounces at all justs sits nice and even. I took it on a 3 hours ride and ran it to town wide open for about 20 min and it dint miss a beat. I am so happy i bought this S .H The story behind it is also neat as it was solt to the farmer on april 12 1954 in elseworth minnesota. That is very near the old stone post that marks the minnesota 2 sides to the south is iowa and west is south dakota. north and east is minnesota. I thought there would be somthing more there but just a stone that looks like a grave marker and a story about the 3 states meating up. It was surronded by fields and it was right off the road. they were fixing a tiny bridge that fead a gravel road. So thats where she lived all her life till i went and got her last year. The hardest thing it does now is pull a tiny trailer to go on picnics with. I like her just the way she is as the picture dosent do it justice it looks even nicer in person. It has a rare hour meater on the light box. The hydrolics are live.
MN Scott
05-29-2007 18:57:36
 Re: here's my super H in reply to jonnnny2006, 05-29-2007 18:27:04
That is not a factory IH wide front. IH only made two styles of wide fronts for the SH. One with the tie rods out in front and one with a cast center bolster. Yours is an aftermarket one not made by IH. It most likelly is stamped "IH Universal" because it fits many differant IH tractors. If you look at the frame that bolts to the tractor it most likelly has several holes drilled to fit several tractor models.
jonnnny2006
05-29-2007 21:12:40
 Re: here's my super H in reply to MN Scott, 05-29-2007 18:57:36
well thats cool. on the tag is has a serial number and the tad said it was mfg by international haverser. dont know what to tell you. other people said the same thing about the wide front until i showed them a picture of the serial tag. I knowm what i got. and there is not any holes drilled out any where. it is just the way it came from the factory. but the tractor did come with a narrow front also. so i don't know when the wie front was added. but i know its not schawrtz
jonnnny2006
05-29-2007 21:33:57
 Re: here's my super H in reply to jonnnny2006, 05-29-2007 21:12:40
it may vey well been mfg for i.h. but im not sure. the tag says IHC model H and has the no 56 on it and also has a serial number. it has a caption on top hat says "if it dosent say uni-versal..." i cant read the rest. It probaly was made for ihc by some one else. but it has the letters IHC stamped right into the serial tag. It is the only one i have seen like this. It looks like the adjustable wide front in the book but i'm not for sure. it works really good and thats all that matters to me. but I must admit that my prior post could be wrong. If it is a uni-versal I wonder what else it will fit?
MN Scott
05-30-2007 06:44:26
 Re: here's my super H in reply to jonnnny2006, 05-29-2007 21:33:57
There most likelly were several companys that manufactured wide fronts over the years. I have never heard of universal but anything is possable. The fact that it has its own serial number is proof in itself that IH did not make it. IH only assigned serial numbers to engines and whole tractors. But like you said who made it doese'nt matter, tha fact that its on the tractor and it provides benifits over a narrow front is all that really matters.
Pat H
05-29-2007 13:44:46
looks great !!
was wondering, is the motor serial number 23953?
it should be stamped into the block below # 3 spark plug. just got the gas tank put back on # 28703 super H last weekend, had a leak where the threads were sweated in for the sediment bowl. over the years somebody probably overtightened it. Pat in Wis
lawmar
05-29-2007 09:54:06
I may be wrong but I thought the StageII were not made until sometime in mid 1954.
MN Scott
05-29-2007 11:22:26
 Re: here's my super H in reply to lawmar, 05-29-2007 09:54:06
The Super H stage II started production in late 1953 with serial number around 19000.
golf cart
05-29-2007 05:45:33
Nice Super H with excellent sheet metal, do you plan on restoring it?
golf cart
05-29-2007 05:43:52
Nice Super H with excellent sheet metal, do you plan on restoring it.
jonnnny2006
05-29-2007 04:05:45
third party image
i just had the wrong url.... its been a long night! heres my s.h. thanks allen i got it now! lol
Allan In NE
05-29-2007 03:35:23
third party image
jonnnny2006
05-29-2007 03:59:41
 Re: here's my super H in reply to Allan In NE, 05-29-2007 03:35:23
thanks allen. what did i do wrong so that my pic could not be seen? what can i do in the future to add pics like you did? thanks ahead of time.
Allan In NE
05-29-2007 04:40:50
 Re: here's my super H in reply to jonnnny2006, 05-29-2007 03:59:41
After the picture is uploaded, open the picture, RIGHT click on the picture itself and then copy that address.
You copied the page address up at the address bar instead. :>)
Allan
jonnnny2006
05-29-2007 05:00:58
 Re: here's my super H in reply to Allan In NE, 05-29-2007 04:40:50
its been a long night! i figured it out what i did wrong after i asked what i did wrong. thanks though, This super h was orginally sold out of elsworth minnesota. I bought it from a guy who bought it to sell it from the orignal owner. it even has the orignal paint job. always stored inside. We took it for a 3 hour cruse last night and it was beautiful out! kids went the dog road with so did my wife dana! We always have a good time with Super H!!!
BOBM25
05-29-2007 10:14:55
 Re: here's my super H in reply to jonnnny2006, 05-29-2007 05:00:58
Looks like live hydraulics without remote control valve? Is that where the resevoir sits when you don't have remote hydraulics? My MTA has the resevoir under the back of the fuel tank, right by the steering post.
