Looking for some reasurance or opinion on my H
Jim-In-NY
05-29-2007 18:34:24
I had some transmission issues that i decided to fix this spring. I replaced the third and fourth gear on the countershaft and the fourth and fith on the top shaft (both used) along with a new driveshaft. After i put it back together it had a whining sound. I thought that it might have been the driveshaft big gear rubbing against the countershaft gear. I shimmed it out and that didnt solve the problem.
i was thinking maybe it was a bearing but if it didnt have this problem before it shouldnt know right? Could it be the new driveshaft not meshing with thecountershaft well. It should break in right?
I checked it for play and it does have a little not really side to side like a bad bearing but a little slop in it.
so what do you think? all opinions welcome
thanks for your help
James
John M
05-30-2007 03:23:15
 Re: Looking for some reasurance or opinion on my H in reply to Jim-In-NY, 05-29-2007 18:34:24
Not meant to insult, but you didnt put gear oil back in, right? Dont ask how I know.
jim-in-ny
05-30-2007 04:12:43
 Re: Looking for some reasurance or opinion on my H in reply to John M, 05-30-2007 03:23:15
no it had gear oil in it.. i did drain some out last night to look at things to make sure it wasnt something else
but thanks for the input
CNKS
05-29-2007 19:31:11
I don't know, but unless you replaced them with a matched set, you could get a whine since the wear patterns are different.
IHC-Farmall
05-29-2007 19:30:05
If i was you i would have just sold the H for junk/parts and got a different one. Up here you can buy H's for about $700 with good tin and tires. Leo in WI had an H on photo ads for $800.
