Stepped head pistons in a early M?
Patrick Martin
05-31-2007 19:19:50
Question guys :)
My two M's have flat top pistons which make them of course regular M's.
Right now I know I will be changing the sleeves out and "maybe" one piston. If I do happen to find more bad pistons then if possible I'd like to get the higher compression and bring the engine to Super M specs IF that is all that has to be done.
Do I need to change the cam and carburetion for this????
georgeky
06-01-2007 12:40:33
 Re: Stepped head pistons in a early M? in reply to Patrick Martin, 05-31-2007 19:19:50
Patrick, I meant to say 400 pistons instead of sleeves. I don't think the sleeves from a 400 will fit in a straight M, however they do make sleeves that will fit the M and use the Super/400 pistons in. Still taking it to 264 CI.
georgeky
05-31-2007 21:48:44
You can take the M from 248 CI to 264 CI with a rebore kit. 264 pistons are 4 inches across. Straight M is 3 and 7/8. You can go with the 264 kit and still use your old cam and carb. Measure your pistons to see if they are stock. Most old Ms have already had overbore pistons put in them. I have two, one with M&W pistons and one with IH Firecraters in it. Both have stock cams and carbs. As Jim said the 400 sleeves are as big as you can go.
Janicholson
05-31-2007 19:26:23
The best option (opinion) is to use fire crater pistons in the largest bore it can handle. I think 400 sleeves will be the bigest, but I may be wrong. Domed pistons will help take advantage of modern gasoline. A 450 cam, carb from a 400 or450, and the manifold to match is the ticcket. JimN
