140 Hi Clear Fast Hitch Photos
Mark Peters
06-05-2007 16:31:39
Richard Heath,Hugh MacKay and any one else who`s interested.I`ve posted a couple of photo`s of the 2 pt fast hitch on my 140 Hi Clear.A couple pics on Parts & Pieces and a few more on Tractor Photos.It`s nothing like the 1 pt FH. No helper spring, just the rod from the touch control arm to the rockshaft in back.From what I can tell ,all it`s really made for is a FH tool bar or a drawbar.They had sugar cane bedders on the tool bar when I bought it. I collect 2 pt implements for my Super C and have about 16 or so implements for it and the only other FH implement I own, other than the drawbar, that will work on the 140 HC is my platform carrier. The hitch sits so high that you can`t really even get the hitch lowered far enough to back into the prongs on a FH implement.All in all it`s a pretty neat set-up though. Mark
SuperA-Tx
06-05-2007 19:22:06
 Re: 140 Hi Clear Fast Hitch Photos in reply to Mark Peters, 06-05-2007 16:31:39
Mark,
Do you have any cast numbers off the front wheel weights? I want some for mine and to be honest never seen front weights for a 140 before. I want to make sure I buy the right ones.
Real pretty tractor. Liked that deluxe seat too.
Hugh MacKay
06-05-2007 16:55:33
Mark: Thanks for the photos, very interesting. I note the rear rockshaft looks much the same as the older type rather than the conventional one point fast hitch rear rockshaft. This hitch also increases clearence greatly over what the one point fast hitch would have on that tractor.
Richard J. Heath
06-05-2007 17:58:57
 Re: 140 Hi Clear Fast Hitch Photos in reply to Hugh MacKay, 06-05-2007 16:55:33
Added a couple of photographs myself. My tractor was sold in Oakdale, La November 28, 1972 for $2,675.00. Equipped with dual hydraulic systems, power take off, eed plat drive, draw bar, deluxe seat, front mounting frames, front cultivators, front mounted fertilizer attachments. Wonder how it wound up with a fast hitch?
Hugh MacKay
06-07-2007 19:19:03
 Re: 140 Hi Clear Fast Hitch Photos in reply to Richard J. Heath, 06-05-2007 17:58:57
Richard: I expect the hitch got changed within two years of tractor purchase. There were periods in the past 50 years, by times new tractors were scarce, and to get one equiped exactly as you wanted it was close to impossible.
Today these dealers know exactly what all neighboring dealers have in stock, and they have access to that inventory. In the days of IH, even the parrent company wouldn't have had access to a particular dealers inventory. Some dealers did have arangement with other dealers they had made friends with over the years, but it was rather loose arangement and had more to do with unloading inventory than the other guys needs.
I suspect the customer in the case of your tractor either took tractor as was and found a hitch from another dealer, or he may have decided he needed the hitch couple years after buying tractor. Remember fast hitch was always an option, and some percentage of fast hitches were installed after the fact. I can remember complete fast hitches on display at my local dealer. Wide fronts were the same for C, H and M size tractors, in those days they were all shipped with narrow front, as more would fit on truck or rail car. I've seen flat bed rail car loads of tractors with various components like wide fronts, loaders, hitches straped to deck, under the tractors.
