1963 IHC Tractor
Richard E Smith
06-19-2007 14:54:12
Hello,
I need help with what weight oil the Tranny in my 1963 International tractor uses . Also does the PTO unit use the same? I have a book on it that states how much each on takes but not the weight for either one.
Thanks
Richard
Jimer
06-19-2007 17:31:33
 Re: 1963 IHC Tractor in reply to Richard E Smith, 06-19-2007 14:54:12
I have a 300u that I believe is a 1955 model. I am of the impression they only made them in 1955 and 1956. Is my info wrong? where did you find the 1963?
Richard E Smith
06-20-2007 05:08:01
 Re: 1963 IHC Tractor in reply to Jimer, 06-19-2007 17:31:33
Thanks Jimer
I was under the impression that it was a 1963 .
The tractor number is 25863 SJ . My book tells me what the SJ means. I took for granted that the last 2 numbers of the serial was the year, as with some boat motors. Looks like I was WRONG.
Thanks everyone for all Your Help !!!
Richard
georgeky
06-19-2007 18:48:05
Jimer, you are correct. 55 and 56 was it. They did make the rowcrop version in 54 as well.
georgeky
06-19-2007 15:55:02
Is it a 140 or a bigger tractor. Not much info there. If it is a 140 it uses 90 weight or heavier. If it is something else it will probably need Hy-Tran or equivalent, the same goes for the PTO.
Dave_Id
06-19-2007 15:51:10
What model, and does it have a Torque Amplifier?
Richard E Smith
06-19-2007 16:45:33
 Re: 1963 IHC Tractor in reply to Dave_Id, 06-19-2007 15:51:10
Hello again ,
Its a 300 U , with Torque Amplifier.
The trans takes 28 quarts and the independent PTO takes 2quarts.
Thanks
Richard
Dave_Id
06-19-2007 18:23:49
 Re: 1963 IHC Tractor in reply to Richard E Smith, 06-19-2007 16:45:33
Since it has the Torque Amplifier, then you need to use a good grade of hydraulic oil such as Hi-Trans from IH. The same with the live pto. As the other guy suggested, the 300's weren't made in '63
