Gas fuel line IH ferrell not compressing problem??
John in Ct
06-19-2007 18:16:40
I made up a new fuel line for my IH 154 Cub Lo-Boy and can't get it to seal 100%( trying for months) at a new IH Sediment bowl. I am using an IH ferrel nut and the ferrel won't compress tight enough around the new fuel line? Any ideas? Can I use a regular ferrel? I don't want to overtighten the fuel line at the sediment bowl. Thanks!!
chad504
06-20-2007 11:42:25
 Re: Gas fuel line IH ferrell not compressing problem?? in reply to John in Ct, 06-19-2007 18:16:40
I stopped mine from leaking, by getting the ferrule back on the line, and sliding it about an inch farther back. Then I took a round tapered chisel, and tapped it into the line to swell it a little. slid the ferrule back forward, till snug. I added some loctite thread sealer on the threads, just to make sure.
Gary in Mozarks
06-19-2007 20:37:30
I replaced mine with a neopreme o ring Worked fine
Steve2007
06-19-2007 20:00:02
Had same problem two weeks ago local hardware store had them but the end piece was not long enough IH brand is thicker and long enough with just afew turns and no leaks.I screw up make sure u have not screwed hardware so tight you have cut that copper line
J Fred
06-19-2007 18:35:12
John as i recall i had to buy fittings from IH.
i believe they are a special type fitting.
J FRED
