300-350 weight
Jim McVay
06-21-2007 17:21:54
How low can you get the weight of a 300-350 and still use the cast rear wheels. What all can you take off to get the weight down???
William Sill
06-21-2007 19:28:05
 Re: 300-350 weight in reply to Jim McVay, 06-21-2007 17:21:54
my 300 with me on it, wt is 4930 no fast hitch , no fenders, no fluid 13.6 -38, standard cast wheels,no belt pully, as a front wieght bracket need to strip 430 pounds ?
georgeky
06-21-2007 18:21:17
I don't know what is going on with Tractor data.com it says the 350 weighs 4100 and some odd pounds, mine is hevier than that. It was weighed on certified scales.
georgeky
06-21-2007 18:17:46
I pull my 350 diesel on occasion and with me on it she weighs 5250. That is with cast spin out wheels and no fluid or weights. I was really suprised as it is 125 pounds hevier than my M. You can drop the fenders,belt pulley unit,fast hitch and even the PTO unit and loose a little provided your tractor has these things. Mine had all of it except the fast hitch as it is not legal to pull with a movable drawbar here.
