Farmall M Hydraulics ( 3 point hitch conversion)
Daniel T. Maxey
03-01-2002 20:13:47
I have a 1949 Farmall M with a belly hydraulic pump. I am looking into adding a saginaw 3 point hitch. My questions are: Do I need live hydraulics to have down pressure? How could I convert to live hydraulics? Where could I find the parts I would need? I would deeply appreciate any help I could get!
chuck
03-01-2002 21:37:37
 Re: Farmall M Hydraulics ( 3 point hitch conversion) in reply to Daniel T. Maxey, 03-01-2002 20:13:47
Dan,
No you dont need live hyd to have down presure. I have and H and I just changed mine to have down presure. You need to buy a spool valve. I got mine at tsc. I ran min from one of the supply nipples to the in side of the spool valve and then you run the out from the spool valve back for a return. I put a T in the drain for the belly pump and plumbed it to there. Then you run hose a back to the back of the tractor and T it off to the top of cylinder. Do the same to to outlet b off of spool valve. But run it to the bottom of the cylinder. When you use it you have to keep the belly pump rod locked in the pulled out pos. Hope this helps if not email me and i will send you pictures of mine.
chuck
03-02-2002 04:20:54
 Re: Re: Farmall M Hydraulics ( 3 point hitch conversion) in reply to chuck, 03-01-2002 21:37:37
third party image
Test
